Pipewelder
Jul 15, 2013Explorer
Saliun S637
Okay... I rolled the dice! Put a set of Saliun S637 today. How are they holding up for those who have put them on?
dbbls wrote:thomasmnile wrote:I stand corrected. They are made in Wichita according to an e-mail from Goodyear. I received some misinformation at a recent Rally I attended. Was told there was not a single trailer tire made in the US.dbbls wrote:
Even the Goodyear G614's are made in China. Goodyear owns the plant but it is in China with Chinese workers.
No, unless China annexed Kansas. The G614 is manufactured in their plant in Witchita, KS.
Me Again wrote:
Maybe in a coupe years there will be a load range G XPS RIB or R250!
If the chinese can do it, why not the French or Japanese?
Also remember that the Sailun is just a standard LT tire and according to you know who would be bad choice, being re-grovable and re-treadable and has to deep of tread and built similar to the two tires above. He will never endorse use of this tire on a trailer, most likely starting another campaign against it. Chris
jimmyfred wrote:
............(2) questions on the 17.5 Sailun tires , (1)do they come with a steel matrix within the sidewall like Ribs do , and Sailun does not publish the weight of their tires on the specification sheet , so does anyone know the weight of their 17.5xxx tires ? , thanks , jf
Look here S637 info 56 and 63 lbs for the 2 different 17.5 tires. Can't answer the other question.
The 16 inch tires are 61lbs for those of you wondering.
