Pipewelder
Jul 15, 2013Explorer
Saliun S637
Okay... I rolled the dice! Put a set of Saliun S637 today. How are they holding up for those who have put them on?
Cummins12V98 wrote:
I personally like to hear about different products and WHY someone likes them.
Tireman9 wrote:NC Hauler wrote:
Look like great tires to me, especially seeing as how they've met more than several Quality and Management control processes( ISO9001, ISO14001 and ISO/TS16949)....Unlike a lot of China made tires, these people seem to want to build a quality product. My OWN company has met all the above criteria as a world wide Tier One Supplier and it's not easy....All one has to do is the research...MOST Chinese made tires DON'T have the credentials these tires do...IF reports stay good, when time to replace my G614's...I will be looking hard at the Saliun S637...again, if you look at the company's QUALITY EARNED credentials, you'll understand why nowhere NEAR the negatives as other "may pop's" manufactured in China...again....do the research....as of now this tire would be the only one I'd look at made in China at this time to replace my OEM tires...
NC
Where did you find the ref to ISO standards for Sailun?
If in fact they have meet these requirements they are clearly head and shoulders above all but the "Majors" (MI, GY, BS, Cooper, Toyo, Hankook, General)
If you want to supply "Detroit" big 3 you must be TS16949 certified. Loose the certification and you can loose your business.
To those that don't know what these standards mean ask your RV manufacturer if they or any of their suppliers are ISO/TS16949 or were QS9000 certified? I would be surprised if they even knew what "ISO" stands for.
Me Again wrote:Wiley75 wrote:
You opinion that GY is the best "hands down" is just an opinion.
I never said GY tires were the best, I said that how they handle tire failures was the best, hands down!!!
Time to close was based on the name calling, not the tires.
You seem challenge in read and understand?
Chris
NC
ISO standards are easily found referenced by any tire manufacturer that sells tires to the auto industry.
Click Here
Sailun certification
FE
Rob_Fla wrote:
Most tire issues still come down to weight.
If you are loading any tire at its weight limit, it will run hotter, wear faster and be more prone to failure.
We all know that many of the RV manufacturers put Axles and Tires that are marginal at best and look good in the brochures for dry weight, then when we add options like 2nd A/C, Larger Refig, Generator, Dual Pane Windows and such the actual weight goes up the carrying capacity goes down and the RV gets close to the Gross Weight Rating of the axles and tires.
When running a trailer or 5er with a loaded weight of less than 12,000 lb. axle weight with a "G" Rated tire, they should last forever if the trailer is balanced and there is not more than 3,000 lbs on each tire. When running axle weight above 12,000 or more than 3,000 lbs per tire, even the "G" rated tire is getting a workout, this is the reason many have moved up to a 17.5" tire.
If you look at the brochures and then go on the lot and look at the yellow label the manufactures are required to put on RVs today that show actual "As Built" weight, many of them do not have much carrying capacity left before hitting max weights.
If more RVers had their trailers weighted with all their stuff as they travel, they would be surprised.
Like the dealer telling the 1/2 Ton Truck owner, "You can Pull Anything in the Lot"
If you can pack it in the trailer and still get the door closed, it must be Ok !!!!
We actually have 7,000 lb. axles but the manufacturer de-rated the axle weight rating to 6,800 lbs. since they put "E" Rated 3,400 lb. tires on the axle.
up2nogood wrote:Cummins12V98 wrote:CKNSLS wrote:Cummins12V98 wrote:fj12ryder wrote:
You've never had a blowout with damage, but you'll swear that GY will cover it if you do. As long as it isn't road hazard, and you can prove to them that it wasn't road hazard. Riiiiight, and I'll respect you in the morning. :)
I think I'll try the Sailun and see how it goes.
I don't have to prove anything. Yes I do trust they will cover the tire and damages if it is non road hazard. Don't believe me listen to NC and the MANY others on here that have been taken care of by GY.
That is an unbelievable post. Others said it on the Internet-I am sure it will work for me too!
I can't believe the rhetoric on this forum when it comes to tires. Anything will be said when you mount a Chinese Companies tire! ANYTHING!!
If you have read what I have said my Dad has been taken care of by GY for damages.
You can call him a liar also if you want.
I don't believe anyone called anyone a liar, but what good is a tire that fails, as I said there is little consolation to see your trailer all tore up sitting on the side of the road, to me the last thing I would be thinking is I hope the tire company is going to fix my trailer, that may come later ,but at the moment I am dead in the water until I get a tire or tires changed, and get myself back on the road. I would much rather have a tire that I can trust, and GY really has not proven that, been plenty of failures .
Me Again wrote:
Here is what I have learned as a snowbirder and having talked with many people that have had tire failures. Goodyear is the best hands down. They would like you to claim it on your insurance and they will pay the deducible! If however you do it correctly with them, they will pay for everything, and it some causes give you 4 new tires, not just the one that failed.
You must have the failed tire and get a Goodyear dealer to ship the tire in to them. No tire no deal.
This spring a friend lost a Commercial TA and BFG/Michelin fixed his trailer and provided one new tire.
Few if any of the 2nd tier tire provides will pay for trailer damage, period!!!! It is excluded in just about all tire warranty statements ( including Goodyear's) as consequential damages.
So if you want to save a 100 dollars per tire on these Saliun tires that seem to be getting good review "so far", then great! Just understand that if one fails you will most likely not get the "Goodyear treatment"!
I could run much cheaper tires on my trailer and most likely never have a problem over the short haul. However we tend to keep things many years and buying the best has paid off in the long run for us. Your experience may vary!
Time to close this one!!!!!
Chris
