Old-Biscuit
Jun 10, 2021Explorer III
eHoefler wrote:
If the 4 bolts are over tightened, it will warp the pan and allow the condensation to leak inside. The manufacture spec is only 14 ftpd, which is barely snug.
Also, If you are in a high humidity area, and using the blast vent on the cover, it will condensate on the grill and drip, that is not a leak per say. The only way to combat this is to close the blast vent and send the air through the vents,
That spec is INCH Pounds...NOT Foot Pounds
About Fifth Wheel Group
