hottub's avatar
hottub
sat dish
looking for best sat. dish for fifth wheel.
1. must be able to pay to go
2. must be able to get eastern and western sat.
3. must be capable of operating 2 tv's on different channels
4. being installed on a prewired for sat cedar creek.
question... would you roof mount with the concern of not getting signal in a shady campsite? or set up on tripod
Thanks
  • The Dish Playmaker offered by Dish, no longer need to be pointed north. The Tailgater has conflicting instructions about positioning north. The Winegard App will not run on my iPhone and has poor reviews. I use SatFinder Lite and it works fine.
    Pretty darn clear to me: Set up your Tailgater, Pathway, or Playmaker. Take the guesswork out of setting up your DISH portable antenna. Place your portable antenna outside on flat, level ground. Make sure it has a clear line of sight of the southern sky and ensure the coax ports point north.
    The Android phone app works excellent for OTA & Sat. It works with all sat systems and in AR view I can look at the sky with the phone & see the sats. If my phone sees them so will my antenna & I know exactly where to place it if I'm in trees. Have no idea how the Apple app works as I wouldn't purchase an over priced propitiatory anything, but that's just me. Don't have a lot of experience setting up being 3/4 time and 10-12K a year in my RV, experience Vs reading some article.
  • We have had the DISH Tailgater for 3 years. It works ok, unless it's raining hard.
    We decided to get a roof mounted dish antenna. I researched a lot and decided on the Eagle TV Automatic Antenna System It's user serviceable and can be converted from Dish to Direct tv easily.
    KEN
  • I have dish here in Canada I put it up on roof of the trailer or can move it around to get signal. My buddy has his on the roof and some times cant get signal because of trees
    On the Dish website there are two different sets of instructions for the Tailgator, one mentions the north and the other does not. My Playmaker has no such requirement.
    The reviews on the Winegard app mentions the exact problem I am having. The Apple app should work exactly the same as the one for cheap phones, but it crashes. The SatFinder app works well.
    KEN
    Thats a great setup, but was talked out of it by the dealer. He asked me one simple question do you camp in the trees, and the answer was yes . I have had to move my portable dish a few times , or cut a few branches off if its allowed.
    My advice to anyone , if you are going with a permanent roof mount dish ,you better be in the wide open spaces ,and not in trees or where there is something to block the signal.
    Maybe you need a cheap Android works well with the Winegaurd app, no crashes. Apple is like driving a Lincoln truck, flashy but not much use working.
  • Dish Tailgater pay as you go here for about 6 years and yes what was said above the directions are confusing for which is the front is as it shows the handle being aimed South in the instructions I tried that when I first got it and it would not work untill A guy in the Resort told me the Handle is the BACK of the tailgater so I turned it around and Bam! been enjoying it ever since and also I just put mine on the ground or on my roof if a big RV parks next to me blocking my Southern Sky I don't need no sticking Tripod:B and I have never used a APP to find Satellites Up here in the NW I just aim it a little SE and good to go:)
    KEN
    I kept our Dish Tailgater just in case the trees give us problems. So far, so good.
    With the roof antenna, the Dish Hopper works like at home and the recording can happen, then the commercials are gone (zipped thru). KEN
  • ORbiker wrote:
    KEN
    That would be the only solution, but many I’m sure do not want to purchase two satellite dishes .
