lightfoot
Sep 17, 2014Explorer III
Satellite wiring in Voltage 3200
I received a Tailgater satellite system and seem to have a wiring issue with the satellite portion of the system. I have gotten the Tailgater to work outside of the trailer, but when I attach the RG6 cable to the satellite connection and plug the receiver to the internal connection, I get no connection to the dish. I have traced the white satellite wire from the outside to the area below the sink in the bathroom. The wire runs up the wall between the sink and the hallway, so I assume that it is heading over to where the living room tv is located. Behind the control panel I find 2 white wires, but they are both connected to a splitter. One is attached to the input of the splitter and the other to an output port. If I disconnected the output one the outside and garage tv's stop working. If I remove the input white wire, all the tv's stop working. When I trace the 2 wires attached to the outlet that is in the opening under the DVD player, I find that one goes to the splitter and the other heads up the back wall and behind the tv.
Anyone got the OEM wiring working and/or have any ideas how the trailer was wired? I have a diagram that shows a direct connection from the outside satellite connection to the inside under the DVD player, but that does not seem to be the way mine is rigged.
Thank for any help.
Bob
Thank for any help.
Bob
