tporter's avatar
tporter
Schwintek slides
We have gone from a small travel trailer, to bumper pull trailers, a fifth wheel, and a class A motorhome. We sold the motorhome and now are looking at fifth wheels again. We have narrowed our search down to the Keystone Montana, Jayco product, and possibly the Grand Design, Solitude.
I have been reading a lot of negative posts on the Schwintek slide system. I believe that Jayco and the Grand Design use this system but not the Montana. Is the Schwintek system really that bad or have they fixed their system? Am I correct that the Montana uses a different brand / system?
  • Carl n Susan wrote:
    racer4 wrote:
    [snip]
    The Schwintek slide system is most often used on the smaller, lighter bedroom slides.
    I usually look at pictures of the slide, looking for the shiny aluminum tracks on the side of the slide near the top and the bottom. Those tracks are what you see on a Schwintek.
    Look at the first picture of this slide on a Montana. Do you see the shiny tracks?
    [/snip]
    The Montana does *NOT* use the Schwintek system. Those "..shiny tracks.." you reference in the picture are cables. The front room in a Montana is cable actuated.
    Cables good or bad?
  • racer4 wrote:
    [snip]
    [/snip]
  • The Schwintek slide system is most often used on the smaller, lighter bedroom slides.
    On edit: Correction, according to others the shiny "thing" in the linked picture above is a cable. I was seeing the cable and its shadow, making it look wider. So, when looking at the side of a slide, I need to distinguish between an aluminum track (Schwintek), an aluminum cable (cable slide) or nothing (regular electric or hydraulic slide).
    Now look at this one. No tracks visible. I think Silverback uses hydraulic slides.
    Here is a closer look at the Schwintek tracks so you know what you are looking for.
