Pangaea_Ron
Feb 02, 2015Explorer
I used 6" diameter corrugated black plastic drain pipe, and attached it to the under frame of my MH with SS pipe clamps. The pipe itself is flexible and can fit around and conform to the MH framing. Rather than end fittings, I drilled holes at each end and dropped carriage bolts into the holes to keep the sewer pipe and fittings inside. Another advantage of the drain pipe is that it has drain holes to allow the sewer hose to dry.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
