rhagfo
Mar 01, 2016Explorer III
N-Trouble wrote:
The MorRyde isn't designed to reduce hitch slop. If you have hitch slop it will be there regardless. Looking to soften/dampen some of the for/aft jarring that gets transmitted from 5er to TV due to the tight connection of the ball/coupler.
So in my opinion the for/aft push pull is caused by two things.
#1 Nose high attitude, the back axle has a harder time over bumps, and the equalizer can't really compensate for it. This results in a pull-push effect when that axle goes over a bump.
#2 Light pin, while stated OK with 15% to 25%, I feel the closer to 15% the more of a teeter-totter effect, and if nose high this is aggravated. Running at least a 20% pin weight will reduce the teeter-totter and result in a smoother ride.
About Fifth Wheel Group
