Well getting closer to my purchase of a 5th wheel. My cousin got a great deal on a pull rite hitch, and gave me the plates that came with it. ( his plates are in good condition and the pull rite simpl...
Second on the Prodigy. There is a blue connector tucked in the harness, should be up over the emergency brake that the controller will plug into. If the harness is not in the glove box, then Dodge parts can get you the piece you need. Then it's plug and play. If you are using the Pullright hitch, then follow the Pullright instalation directions.
