WackAway's avatar
WackAway
Need advice on setting TPMS alarms
I just got a Carchet TPMS System for my 5'r which has max/min alarms for pressure and a max temp alarm. What would be good settings for these alarms given a load rating E tire? Baseline pressure is 80 psi cold (70 degrees). The sensors screw onto the stems, so I do realize the temperature readings probably are not close to inside tire temps.
Max Pressure = ?
Min Pressure = ?
Max Temperature = ?
Thanks in advance
