C.B. wrote:
An 8' fence post cover is $25.00 at Lowes. If your 5er has a rear bumper you can use large zip ties( $5.00 to $10.00) to attach post cover to it. I you want to keep cost down don't buy end caps or rain gutter. Just drill holes thru at the ends of post cover and drop 6" bolts thru to keep hose and connectors in.
C.B.
And there you have it....on the cheap!..:C
LOTS of folks use a similar set-up (me too).
For me the pull-out rain gutter......is used for a sewer hose support when needed between the RV & the in-ground sewer dump.
Cap on the post is a simple hinge arrangement utilizing a $2.50 post cap with a tie at the bottom.
Be as creative as you like....sometimes "on the cheap" is way better than store bought..;)
BTW - *If* you are in a hurry to get going, a large plastic storage container in the basement will do just fine..;)
