Armand_C wrote:
BarneyS wrote:
Here is what I did for mine. I made three of them. One for myself, and one for each my two sons who also have RV's.
Got all the supplies at Lowe's
The far end of the trough is open so it can be used as a hose support if needed.
Barney
Man that's a beautiful job you did! I think I'm gonna do that for the second length of hose. I can't tell what the mats you used are though.
I used
these 5x5 inch vinyl fence posts from Lowes.
Used
these gutter lengths for the trough.
Used
these gutter end pieces to close the one end of the trough. Fastened them on with 2 pop rivets in the slanted part and hot melt glue on the sides. Left the other end open so it could be used as a hose support when needed.
Used
these end caps which are held on via a 6 inch long bolt and wing nut. Never had one come loose while traveling. Hardest thing is getting it through the hole in the bottom, especially if you are in a hurry!
I pop riveted a
galvanized pipe strap to the end cap to hold the tray in place. The bolt goes through this and then through the bottom hole of the tube and cap. Holds the whole thing together very well.
Finally, I used some thin bar stock to bend and make brackets (which you can see in the one on the right side of the picture )to hold the whole thing to the bottom of the trailer and I fastened the whole thing up with self tapping metal bolts into the frame on each side. My sons both put theirs on the rear bumper held on with heavy zip ties.
These were very easy to make and have held up for quite a few years and many miles of travel. They are still on the trailer today. :)
Barney
