Elwoodj's avatar
Elwoodj
Sewer smell
I need help to eliminate a sewer smell coming from the sliding door area going upstairs in our fifth wheel. The door is on the opposite side of the toilet. There are no leaks. I have looks underneath in the storage area and still cannot find the source.
  • Check the vents are clear and the traps hold water.
    What is in the tank should have no impact on what you smell inside.
  • Get a clear fitting. Dump, fill with some water, dump, fill, repeat until it runs clean. You will likely be amazed at how much "stuff" is left in the tank with just a simple dump. I have to fill/dump several times to get it all out. And before all the backseat campers ask, yes, I am using plenty of water to start with after a dump and during usage.
  • Might be a screw on vent cap under the sink thats not sealing.
  • You may have a vent that is pulled up out of the tank.
    If nothing else, use chemicals to stop the smell.
