Fulltimer50
Feb 11, 2016Explorer
Jerry B wrote:Trackrig wrote:
Wouldn't it be too long if it's bending? If too short, it would be trying to pull it longer and straight so speak, wouldn't it? I guess it might depend n how it's mounted?
Bill
The bracket bracket on the spring shackle plate is bent down about 45 degrees and the shock stem is nearly broken off. It appears the shock either stuck(froze) or the shock is too long when the spring is depressed.
Dexter Kit
The bottom plate is supposed to be bent. I had a similar situation. After checking a resent installation, I found that my shocks were 2" to short. The shocks were fully extended when at rest. Gotta check every thing these days. The threads on the shocks were long enough to allow spacers to bring the shock extension in. Will see how it works in April.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
