anaro wrote:
We are in the process of debating between the sabre 5ers (33rets or 34reqs) and TT (320rets). Virtually the same floor plan and not far off on length. Obviously the 5ers are slightly heavier than the tt but within specs for my truck (calculated using scaled tv weights and trailer gvwr not dry weights). Here is my dilemma... the 5er is more expensive and taller. Is it really that much nicer towing to be worth the expense (almost $10,000 difference)? How easy is it to adjust to the height. I worry towing my current tt and it is a lot shorter. Do most figure the difference in towing/backing out pretty easily? TT is a comfort zone for me towing but the 5ers sure are nice. Any input appreciated. Thank you.
I've never had a TT, but I've pulled enough trailers of all kinds over the years, that I knew from the get-go that I wanted a FW. Also helped to have towed a gooseneck a fair amount, so already had experience with the feel of it.
Lyle
