naturist
Oct 22, 2013Nomad II
You will get all kinds of "expert" opinions asking that question here. Some of those opinions might even be useful.
I will not venture to make a recommendation to you, but I will tell you about my experience. I have a 2007 TT that has one of the older style 2-stage converter/chargers. I made the mistake of leaving it plugged in at home over the winter after I bought it in Dec 2007, and in spite of checking the water level from time to time (it was never low, btw), our first trip out I discovered that the battery would not deliver power even though the voltage showed it was fully charged. When you switched on any load, even as small as a house light, the light flashed on and immediately went out, no juice. I had to buy a new battery.
Since then, when I store the TT, I disconnect the battery via a cut-off switch I installed, and I put the battery on a BatteryMinder. It trickle charges at 1 amp, and desulphates the battery, so it is always fully charged and ready to go whenever I want to use the rig.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
