- mowdocExplorer
skipnchar wrote:
My trailer has been plugged in for two years with no problems. Just check water in batteries about once a month until you know if your converter will overcharge them. I have to add water about once every 6 months.
X2 - naytherExplorerI had issues when I had the OEM parallax converter, since switching to a 3 stage 60 amp converter I leave it plugged in all the time. However if I'm not using it for a long period of time, and the fridge is off I'll open the battery disconnect just in case.
- StraboExplorerIve found that motorhomes boil thier batteries, everyone i know has had it happen.
Haulers, no one i know has had it happen. - BadhabtExplorerI have kept mine plugged in since i bought it in 2006 when at home. No issues of boiling the batteries (I still have the original 12V Interstates from 2006).
- NEOKExplorerI keep mine plugged in to a timer so it only comes on for a couple of hours a day when not in use. I use a Flow Rite battery watering system to fill the batteries. The batteries are about four years old with no problems so far.
- 2btowedExplorerThe "cooking " of the batts,depends on several factors,amp output of charger and how many items constantly pulling amps down,also how many batteries you have.If your charger puts out only 3 amps,probably no problem,but you are gonna run the Onan all night to recharge from a low battery state,if a 10 amp charger might boil out the batts if left plugged in all the time. The advantage of 3 stage smart charger is you can set the ranges of charge and it will automatically reduce charging rate as battery is charged.Mine will start out at 80 amps and go down from there.If I am running a small genny I can cut back charging amps so the genny won't cut off.I consider the inverter/charger one of the best things I have installed on my TH,and yes I boondock almost every time I camp.
- LantleyNomad
dedmiston wrote:
So for those of you who keep yours plugged in 24/7/365, how many of you boondock? It sounds like a lot of you keep your rigs plugged in all the time except for when you're on your way to a full hookup site. Many of the Toy Hauler members don't camp where there are any services.
While I don't boondock regularly. I do occasionally go without hook ups. If I need electric I press the button and use the lp Onan 5500. - Old-BiscuitExplorer III
Shore power when available, generator as needed and charging from truck while in transit. Yes we do boondocking also which means batteries have been pulled down and need charging.
Point is.....our batteries are maintained on a charger majority of time.
Going on 7 yrs.
But now I'll probably start having battery problems :B - 2oldmanExplorer IIMine's always plugged in to sunshine. Not a TH, but doesn't matter.
- dedmistonModeratorSo for those of you who keep yours plugged in 24/7/365, how many of you boondock? It sounds like a lot of you keep your rigs plugged in all the time except for when you're on your way to a full hookup site. Many of the Toy Hauler members don't camp where there are any services.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
