armyvet's avatar
armyvet
Short bed hitch ?
I've ordered a new F250 short bed with the 5th wheel underbed hitch prep package. I've towed a 5th wheel many years with a short bed without a slider. I'm getting a new Reese Elite series hitch for the new truck and thinking whether to slide or not. It is almost a $1000 price difference between the two. I know with the nonslider that I have to be careful backing and can not turn 90 degrees. Would appreciate the experiences an opinion of other short bed owners in this regard. Thanks
  • Both good points, I do have an extended pin box and the
    fw cap is slightly rounded at the corners which helps with
    The short bed,
  • You know, its kinda like a 4-wheel drive. Its better to have it and not need it, rather than need it and not have it. I too have a short bed and a slider. I have used it one time and that's it. But the peace of mind knowing its there should a get in a tight spot was worth the extra cost for me. Not to mention its cheaper than a busted front cap on my rig or a big dent in the cab of my truck.
    Just my opinion though.
  • The standard Reese Elite for FW prep kit, will be fairly close to the cab. IDK if the Reese itself, has any forward or back adjustment.
    I have a 13 250 6' 9" bed, and have no trouble turning/backing without a slider. I think it is mostly dependent, on the shape of the FW front cap. Mine is rounded, made to work with a short bed.
    Jerry
