wingsfan20
May 07, 2015Explorer
C-Bears wrote:
At the 2 year mark of full timing, and about 30,000 travel miles, I would have said "have a short bed with slider and never needed it".
That all changed recently. I was backing into a really short tight spot in Florida. Site was a little soft and it allowed my fiver to lean slightly. That was just enough to close the normal 1.5" gap I would have normally had between the edge of my cab and the corner of the Montana when cranked all the way.
If a neighbor would not have yelled at me I would have dented my truck and fiver!
So it is not always just the angle you are at, it could be the tilt of the truck or fiver that could determine it you need your slider on a short bed.
X2
If you are flat, no real problem. Backing up hill and all bets are off. Have Slider but did not use it. The noise of your window being blasted out by corner of trailer is quite loud,
About Fifth Wheel Group
19,040 PostsLatest Activity: May 21, 2026
