Wawhoss wrote:
I own a 27 ft '15 Keystone Laredo 5th wheel and on a trip home from DisneyWorld on Dec 3rd I experienced a blowout on the left rear tire just south of Ocala on the Fla turnpike.I noticed white smoke billowing out of the wheel well in my outside mirror. Got it pulled over and with the help of a friendly State trooper and Roadside assistance got the tire changed in record time.Tire was due to be changed out but that's another story.
My problem is just the other day I was poking around under the trailer and noticed that the front right tire chewed thru the top of the wheel well and I've got an oblong hole in the top of the well right over the center of the tire.I guess when the rear tire lost pressure the front tire picked up the additional weight and came in contact with the top of my wheel well. Checked it today and I've only got about 1 1/2" to 2" of clearance normally. Does this sound like a design flaw that Keystone needs to correct. Thanks
Wawhoss
How are your springs? Could be they've flattened out a bit, causing less space.
Lyle
