Wawhoss wrote:
The springs look fine. I've put less than 5000 miles on my trailer since we bought it new in'15.
Keystone put 4400# axles on this unit and I looked at the hangers and they only have one hole so dropping the spring down one hole is not an option and the axle is under the spring so it can't be flipped.
I have a Keystone Raptor, the springs flatten out on mine, I replaced the springs along with a wet bolts and Dexter E-Z Flex system and it raised my trailer about 2.5", then I had plenty of clearance in the wheel wells.
I hope this helps you!
