Squattingdog's avatar
Squattingdog
Shorter 5th wheels
Hi, somewhat new here,
I did try searching without much success before asking here. We're interested in purchasing used. One of the better build quality 5th wheel trailers closer to 25 feet and not sure what brands/models etc., to look at that area available in our area. Naturally we'll look on-line first such as Craigslist. We're planning on a year (or so) trip so it will be full time. Obviously we will shop in person eventually. We're located in the Phoenix Arizona area.
Regards ...
  • Your two biggies will be the 4 speed auto and the low load carrying cspacity. Packing carefully and 30 feet should be no problem. I think you will find longer is much better for long term living.
  • ... didn't see any of those local to me (Phoenix Arizona). We might go for a 30' but nothing longer. I suppose it would be best to check out the 25' in person. Don't believe our truck will be a problem pulling a 30'er. We have a 2005 2WD Ram Crew Cab HD SLT Automatic with a Cummins diesel.
  • Komfort, Sunnybrook, Holiday Rambler, and Nash too, in older models are good quality.
  • Thunder RV is rhe closest dealer to the factory, Apache Camping centers in the PNW are both big Northwood dealers. You might check their web sites for used Northwood or Outdoors RV products. Might be worth your drive.
    Have you considered a bigger truck and getting a bit larger trailer? 25 feet gets pretty cramped in a hurry. Moving to 30 feet could get you way more closet space, better kitchen, living room etc. At 25 feet you might have a crawl in bed room. At 30 feet you csn get a stand up bed room. Plus there are way more 30 footers.
    Just a thought.
  • Squattingdog wrote:
    Thanks ... I have read about them here but I haven't seen a used Arctic Fox in my neck of the woods, and only 9 or so Northwood 5th wheelers are on RVTrader.
    Yeah they are no-existent in the SE US too.
  • Thanks ... I have read about them here but I haven't seen a used Arctic Fox in my neck of the woods, and only 9 or so Northwood 5th wheelers are on RVTrader.
  • Might want to look for Arctic Fox, they are top quality and make some small units. the RVTrader online is often a good source for used models.
