Gloria E wrote:
True newbie to 5th wheels. Looking to retire. Should we buy used and if so - how old ? What to look or ask for? Desperately looking for some guidance in purchase of our retirement home :) Thank you
Posting without reading ahead...
No problems in buying used and, if you find the right one, can save you a lot of money as well as headaches, a$$-u-ming it's been well-maintained and the inevitable problems have been properly fixed. Shoot, I saw a 1938 travel trailer that has been stored in a climate controlled shop that sold for over $100k at auction. It was only used about 8-10 times, then stored. Everything was in excellent condition and worked as it should. You find something like that, and you're golden.
As far as looking, PLEASE find the FW you like, then see what it will take to tow it. Most common mistake is buying the truck first, then finding out that you need a semi to tow the FW you want. :-)
Don't be afraid to hire a professional RV inspection service, either, as that's well-spent money, IMO, especially if you're new to RVing or have little knowledge of what to look for.
#1 issue to look for is water damage =anywhere= in the coach. It's the biggest killer of an otherwise fine RV and it doesn't stop, even when the leak is fixed. The original damage can "creep" and start causing other problems, especially if it causes structural damage. Don't forget that leaks can be caused by external factors, damaged roof and bad caulking around all the "stuff" that extends out of the exterior, window and slide seals, too. Then there are internal leaks, caused by faulty plumbing.
These are just a few things that come to mind and I'm sure all the others have posted good things to watch for.
Lyle
