MFL wrote:
BugsRLB wrote:
We have a Reese hitch that fits in the 4-hole puck system (or whatever it's called) of our Ford F350.
Is it adjustable ahead/back? Measure from center of hitch hole, jaws closed, level ahead to back of cab, to check distance. If need be, the hitch pin center, can be right over rear axle center. You cannot expect to back to a 90 degree angle, but most turns forward, should not cause the issue you encountered.
Jerry
No it is not adjustable. It fits in 4 factory holes in the bed. Was thinking on some type of movable rotating kingpin.
