klr650goldwing's avatar
Feb 16, 2020
Shower drain clog.
The water in our shower drains slowly. By the time our shower is over we are standing in water. We think it must be a hair clog just because we don't what else would cause it. Our question is what should we do to fix it.
    Take the shower drain coverout on the shower floor. Pour 1 cup of baking soda into the drain then slowly pour 1 cup of white vinegar. It will immediately start to bubble up. Then run hot water until it drains really easily. If needed repeat the process until your shower drains normally.
  • Did u unscrew the cover plate and look in sometimes u can get lucky see it with flashlight nd pull it out with needle nose pliers
  • Another thing to check besides a clog, is the vent pipe for the tank where it comes through the roof. Check to make sure wasps of dirt daubers have not been building a nest at the top of the vent pipe plugging it.
  • I would imagine that it is a super short run to the tank from the shower. Snaking it would be pretty easy. Have you had the trailer for a while and is the problem new? If so, have you also considered checking the vent? Some times they get debris or nests in them.
  • Not sure that's really your problem.
    Our last two trailers were bought new but because they use those tiny little drains in the shower, they just can't seem to keep up all the time. Why the industry keeps using drains from mobile homes built in the 60's is a mystery to me.
    The problem is even worse with super soft water.
