bbaker2001's avatar
bbaker2001
shureflow pump
2001 cardinal has shureflow pump. shows 2.5 gpm, but tested at about 1.8.
pretty weak for taking shower. see newer ones at 3.0. are the newer ones more efficient and any better. I get worried when about to take a 3 month trip.
  • We have the old 4.0 and it works just fine. However, we also carry a spare.
  • mine could not be removed. thanks, I will drill larger hole
    is shurflo still one of the best around
  • Shurflo Classic Series 2088 have been discontinued and VERY limited parts available for repairs
    Shurflo Revolution Series 4008 is replacement......higher flow rate/discharge pressure
    Replace pump now while you can shop for best price OR replace when it fails and options limited
    Proactive/Reactive your choice
    As for weak shower..
    Have you removed 'restrictors'?
    In hose end at faucet (or possibly at shower handle)----disc with small hole.
    Some can be removed---some you just enlarge hole with drill bit
