d3500ram
Jul 24, 2018Explorer III
Shureflow water pump fix...?
Not sure if this may have been discussed in the past: I just de-winterized my truck camper this evening and noticed a very slight leak at the water pump. I have not used the camper and the last time I did this chore was 3 summers ago.
When I de-winterize, I generally will check all plumbing connections and tighten all the flair-it fittings to insure good connections. This time at the pump itself there was a very slight leak, more than just a drip- definitely noticeable but not gushing and tightening the in/out fittings did not solve the problem.
As I stated to un-mount the pump I decided to just tighten the screws that mount the motor to the pump housing case as it appeared this is where the dripping was coming from. For grins I remounted it to see if there would be an improvement... AND there was!
I will still keep a close eye on it over the next few days, but is this a common problem fixed in this fashion? I can envision how, over the years, that pump vibrations could loosen the fasteners such that a leak could develop. I hope that all it was is this simple repair.
Thought? comments?
Thought? comments?
