omextreme
Dec 18, 2015Explorer
Side Wall Ripped/broke while retracting slide-advise needed
I posted this on the Keystone Forum but that forum has less active members so hopefully here is a better place to post.
While retracting my main slide on our 2015 Montana HC the slide started to stall after only moving 10" - 12" inward. I immediately stopped moving the slide and went to investigate the cause of the jam.
While looking at the cables the wall "popped" out and broke away from the frame of the trailer. What appears to have happened is that the jammed slide pulled the wall outward 3", ripping the interior wall and bowing the fiberglass side of the unit.
After looking more closely at the structure failure and I am dissapointed in Keystone on this one. The vertical side wall support was only welded on 1 side to the lower frame. The aluminum tubing tore where it was welded. This location is an EXTREMELY high stress spot since the entire weight of the slide leverages against it.
This area SHOULD have been reinforced with more metal or at least heaver strength aluminum.
Now the question is how should this be properly repaired, It this something you would trust the local shop to handle or should I push for this unit to go back to Keystone and be repaired there?
Thanks
Thanks
