Y-Guy
Oct 15, 2018Moderator
Be sure to do some surface prep so you have a fairly smooth finish. I'm assuming you can't take the panel off completely though. If you have a wall you can probably use a piece of plywood and some compression clamps to hold the filon/glue flat with the plywood as it sets.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
