tko9900's avatar
tko9900
Silverback 29RE
Trying to get the TV off the back wall. It's on a stationary mount, can't figure out how to pull it off the wall. Never saw one like this.
  • Thanks Wingcamper. Finally got it off. It was not mounted like yours. Want to put it on a articulating arm.
  • Mine has an allen head bolt on each side behind the tv. Remove the 2 bolts and lift the tv off the bracket. You may have a long allen wrench for it, that came with the rig. I find it easier to accessthe bolts, if I remove the window decoration that is next to the tv(2 phillips crews in top and 2 in the bottom. I use an allen socket that fits a 3/8's drive extention that I adapt to my cordless drill. Hope this helps.
