- Grady23ExplorerThanks for all the replies so far. I have traveled the Skyline drive(VA) portion of the Pkwy from Front Royal to the NC line. As I suspected, the tunnels could be a real problem as well as campsite availability. Keep the info coming -- Thanks again.
- AllworthExplorer IIWe have spent a lot of time in western NC and on the Skyline in the last 20 years, and I can assure you that working anything more than a popup over the Parkways is a PITA.
Best way is to find a nice campground just off of the parkway and then spend two or three days exploring the area with the TV. Move North or South on the regular highways to a new area and repeat.
Not only are the tunnels a problem, but the scenic overlooks are often SMALL and the weather can change in a big hurry. There is nothing like getting caught above a thunderstorm with a 35 footer. - VulcaneerExplorerExactly what John Bridge said above. We traveled it in a 34 foot fifth wheel that was 12'-8" high. Not a problem at all....AS LONG AS, you travel through the CENTER of the arch tunnels. You nee to make sure you can pass through when no traffic coming the other way, so you can straddle the center line. There is good clear sight lines to do that without any problems.
- John_BridgeExplorerI went through the first tunnel with my fiver which is 13'3'' tall. I waited until I could see no one approaching from the other end and then went through about two feet over the center line.
The tunnels are of the Roman arch type. High in the middle and lower over toward the sides. It can be done. You could even post your co-pilot at the far end as a road guard. :)
The big problem is that there is only one campground you can get a large trailer into, and it's usually packed full. :) - RoyBExplorer IIIBlue Ridge mile markers start at ZERO in VA and ends in NC. 459 will be in NC.
Best bet is get your information from the BLUE RIDGE web sites...
We have traveled the Blue Ridge many times and have camped at their tent sites mostly and many trips with our POPUP. There is a camp ground roughly every 50 miles and only a few places to get gasoline on the Blue Ridge. The real bad areas road wise is getting on and off at the sub roads. Lots of curves and steep inclines... Traveling the Blue Ridge at dusk and early evenings is dangerous due to wildlife. Deer everywhere all along the parkway. Best bet is the major roads ON-OFF points that cross the Blue Ridge...
Its a great trip... The Blue Ridge web site will make you aware of road closures and special alerts etc..
The major storm that is coming up from Texas right now will really be one to watch for the Blue Ridge if you are planning something soon heading down it.. I'm betting alot of road closures will come from this storm...
Roy Ken - MTPockets1ExplorerI found my GPS to be way off regarding the bridge clearances. My Rand McNally was showing the center heights . Although that is correct, the problem was the tunnels are very narrow and the side heights were about 10' .... We decided on another route, then drove thru three tunnels without the trailer. And know we would have been in trouble had we tried to pass while towing.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
