skipnchar
Apr 14, 2014Explorer
If it's not the motor causing problems you might want to look around for water intrusion around the slide room. It can make things swell and bind and will present much as you described. One way to check it is to get out the hand crank and retract it manually using the crank. You should be able to feel very easily is it is binding anywhere.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
