Vulcaneer
Apr 14, 2014Explorer
Michelle.S wrote:
Don't know about your unit, but guessing you're referencing hydraulic slides. Many RVs use an auto-reset circuit breaker in the slide pump power line. These do go bad resulting in a stopping and restarting of operation and will only get worse. I would check to see if you have an auto-reset breaker and replace it.
Have had a similar issue on previous Montana and current Redwood.
This is the correct response. Follow your positive wire from the battery. It will connect to a breaker (actually two in series) that is connected under a rubber cover. Usually a red cover, and attached to the back wall of the front storage compartment. These suckers go bad frequently. Remove both of them and take them to an auto parts store for replacement. About $6.00 a piece.
This is your problem.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
