45Ricochet
Apr 17, 2014Explorer
Vulcaneer wrote:
This is the correct response. Follow your positive wire from the battery. It will connect to a breaker (actually two in series) that is connected under a rubber cover. Usually a red cover, and attached to the back wall of the front storage compartment. These suckers go bad frequently. Remove both of them and take them to an auto parts store for replacement. About $6.00 a piece.
This is your problem.
These breakers are used on electric motor slides as well. Usually 50 Amp breakers with auto reset.
This is for the " stop condition" and not the "weak, strained condition" correct?
Mine just seems weak over the hump in raising the floor. Never has stopped and seems fine other than the lifting while retracting of the slide.
Funny the manual crank handle works fine. I thought I would find binding action but it was smooth as silk.
Not trying to hijack OP, thought it might be related to yours also :B
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
