Vulcaneer
Apr 24, 2014Explorer
OK DDH...You sound a heck of a lot smarter than your dealer. And from your latest description, it does sound possible that things are a little out of shape. Sagging, wear, or out of alignment. After all it happens to all of us at some point.
The weak battery could be a possibility. As could compounding of a little bit of all the issues at once. So it really sounds like it could be a combination of many little things. And one thing that might help is to make sure the trailer is level when actuating the slide out. And to test if alignment might be a problem, purposely UN-level the trailer and try the slide. If the action gets better or worse (with and un-level) trailer, then that could help to determine if there is an alignment issue.
Good Luck.
Good Luck.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
