- Dixie_FlyerExplorer IIIs there a part number you can recall for the circuit breakers?
One more question. When the camper is hooked to the land line power cord the breaker doesn't trip as often, however when I am using only the power from the battery the breakers trip many times before the slides are in. I checked the battery with a volt meter and the battery has 12.4 volts and will draw down to 11.2 during slide out operation but returns back to 12.4 immediately after. When hooked to the power land source the battery reads 13.5 and the slides go out and in most of the time without tripping the breakers. Any suggestions??? - BB_TXNomadWill probably be a 50 amp breaker. But look on the side of the old one to make sure.
The one on the left is for my slides as you can see the large wire going up to the pump. - Any auto parts store will have them.
- Dixie_FlyerExplorer IISo those are the breakers! Where do you buy them from except from an RV dealer?
- BB_TXNomad
Dixie Flyer wrote:
Where were your breakers located. Don't seem to be able to locate the breakers on the 2011 Montana
Mine is a 2007 so it may be different. But here is a pic of mine. The breakers are under the red caps. Pump is directly above the breakers.
And the breakers should not be wired in series. Should be one wired to the pump, and the other wired to all other things. - smurfExplorerGo to NAPA buy new breakers > Easy fix
- Dixie_FlyerExplorer IIWhere were your breakers located. Don't seem to be able to locate the breakers on the 2011 Montana
- JohnG3:
Why would you want the circuit breakers wired in series? - JohnG3Explorer IISame thing happened on our 2009 Montana. Get American made breakers to replace the Chinese breakers that came with the RV. On our unit there are two identical 50 amp breakers wired in series. Mounted on the back wall of the front storage area just above the battery and below the slide hydraulic pump.
- Dixie_FlyerExplorer IIThanks for all the input. Hopefully I can take it from here and repair the problem with the slides
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 03, 2021
