BurbMan wrote:
Sounds like a hydraulic check valve is letting fluid seep by and allowing the slide to extend. The quick fix is to get a pair of these locking poles to keep the slide closed.
Our last Terry came from the factory with these poles to take the pressure off the mechanism keeping the slide closed when going down the road. Just have to remember to remove them prior to opening the slide.
Are you saying the residual pressure is causing it to move? Seems like the pressure would equalize at some point and movement would stop.
I agree locking poles, Pogo sticks or some other type of pole will stop movement. it did not do this when we first bought it. The rear slide (2) is a bunkhouse so there is no way to get back there once slides are pulled in.
I've never had any trouble with it moving while traveling.
