Monty-Rob wrote:
Any thoughts
Two of 3 slideouts work. Our main 25' slide decided to stop working.
Switch does not respond, manual over ride is off, circuit breakers ok, fuses ok...stumped while waiting to see if rv tech can see us tomorrow
Am I missing something? Hidden circuit breaker....your thoughts
Not sure if you got this fixed or not. I had the slide out and mine would not retract to head home. I found I had O power at the slide motor or switch. Tracing back, the 12V connection in the breaker box was loose. Tighten the screw that holds the wire in the box and the problem never came back.
