Tin_Pusher
Nov 19, 2013Explorer II
Ivylog wrote:
Get several people to push on it from the outside while trying to put it in. This may get it in so you can leave.
This has worked for me in the past, worth a try. Only a small shove may be needed.
On my Wilderness, the motor (underneath) has a lever on the back end that disengages the brake. The wiring harness needs to be disconnected from the circuit board as well, else it is REALLY hard to move. There is a hex on the drive you can turn with a wrench.
Yours may or may not be similar. Good luck.
About Fifth Wheel Group
