bear6200ExplorerNov 19, 2013Slide Out will not retract/NW OhioI have a 2008 Carriage Cameo. The Kitchen slide will not retract. It is an electric gear driven system. When activated the slide moves about 1" and the motor starts to "chatter" (clutch slipping). Car...Show More
powderman426ExplorerNov 21, 2013Check the motor for high amp draw. If its ok, you can probably save several hundred dollars by just buying a new pinion.
Related ContentAdding power outlets in slide with no wiringarctic fox slide adjustmentEasy way to remove slide topper?slide out 120v harness issuesslide vs no slide
