dave14117
Nov 21, 2013Explorer
We have an 07 Cameo and had the same problem. The chatter is likely indicative of trouble -- the motor has come loose and no longer engages the gear box tightly, which leads to gears partly meshing. The result is no movement, or not much movement, of the slide, and worse, gear damage. Solution was new motor and gearbox. I have noticed that the gearbox has more holes for mounting than the builder provided motor bolts for; three or four vs two or three, I can't recall. I found this out by buying a gearbox from a third party -- not Alko -- and saw the difference.
It seems the motor comes loose under stress because the manufacturer cut a corner.
About Fifth Wheel Group
