bear6200's avatar
bear6200
Slide Out will not retract/NW Ohio
I have a 2008 Carriage Cameo. The Kitchen slide will not retract. It is an electric gear driven system. When activated the slide moves about 1" and the motor starts to "chatter" (clutch slipping). Carriage is out of business but through a contact I was told that Alko is the manufacture of the Motor and brake mechanism. After searching without any result for a repair shop I was told that I can release the brake and the slide can be manually pushed in. My problem is that the owners manual has little to no information on how to disconnect the motor/brake assembly. Also I have had little to no luck online trying to find any directions or how to videos or drawings. We are stuck until I can retract the slide and get it to a repair shop probably in Indiana. We had planned to leave for Florida in the morning now I am STUCK!
  • If the trail led to Alko, it may be a RBW mechanism.look to see if it has a cable system. If so you can undo the cables and push it in. mine did the chatter thing and I found out the pinion gear on the motor was pushing away. Remounted with am outboard bearing and working ok now.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Get several people to push on it from the outside while trying to put it in. This may get it in so you can leave. Cut two boards to lay on the top to keep it from wanting to go back out once you get it in.
  • Here is the company that made the slideout actuator for my 2003 Laredo.
    Venture Manufacturing
    I had the motor on my slide go bad. They were very helpful in getting me a new motor at a price much better than any other retailer.
    Based on my experience, there is no way you will be able to push your slide in with the actuator still connected. I think you need to investigate what is jamming the slide as you try to bring it in. It appears your actuator is still working - it just can't overcome a jam or binding situation in the slide and that is why the clutch disengages. Even if you disconnect the actuator from the slide you may not be able to push it in due to the jam. If you do get it in, you will need a way to hold it in while you travel otherwise it will come back out on its own.
    Can you manually crank in your slide? My trailer has a hole in the side opposite the slide where you can use the manual landing gear crank to manually turn the actuator. If you are able to do this be very careful. I applied too much force in the wrong direction and broke a shear pin in the acutator. I had to take the actuator out of the trailer and disassemble it to repair the broken pin.
    Good luck in your repairs
  • Do you have access to the slide motor thru an access port under the trailer?
    Chatter sound more like a gear skipping than a motor brake.
    SENDING YOU PM
  • if you can get to it, look it over ,you should be able to take the motor off ,or the drive and push in, question what keeps the slide from rolling out while driving? might ask a buddy for some help..
