hrsnc
Mar 18, 2018Explorer
slide out
I have a 2005 wildcat 5th wheel the switch on the inside dose not open or close the slide outs but the switch in the front compartment next to the motor dose work could just the switch gone bad or should I check something else out before i buy a new switch.
Thanks for the help hrsnc
❚ Did you see the FTS "Announcement : READ BEFORE POSTING HERE"?
- Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds
to the subject of your topic. Thank-you!
Moved from FORUM TECHNICAL SUPPORT
