Happycamper30's avatar
Mar 31, 2019
slide out
I'am seasonal with 2 slide outs did it wise to put slide out stabilizers on each slide out even though I have stabilizers under the bumper and steps to stop sway?
just curious,
Thank you.
  • x2 on jacks supporting the frame for best stability. You can get 3 pair of 3k lb jack stands from Harbor Freight for < $200. You'd spend way more than that for stands for 2 slides.
    Lyle
  • I just picture a tire leaking and now all the pressure is on the slideout. I would high;y recommend against it.
  • Stabilize the trailer frame and the rest of the rig will be fine.
    Barney
  • Carefully read the owners manual. They generally tell you not to use slide supports or goose neck adapters.
    Ken
  • Slide out stablilizers are not recommended. Your unit was build with plenty of support for the slide. If you do use a slide out it is very possible that too much pressure be put on the slide and could cause misalignment or other problems.
