pursuit1's avatar
pursuit1
Slide Outs Not Working
Have a new 2013 Keystone Alpine. Slide outs will not come out. Have done the following:
1. Confirmed battery is fully charged (12.2 v)
2. Tried another battery - same result
3. Plugged into shore power - same result
4. Replaced three slide fuses - same result
5. Replace two in line fuses - same result
Any one have any further suggestions, other than a warranty call to the dealer.
Thanks
  • Have to ask, are you sure that the battery discount switch is turned on.
    If you had the shore power plugged in the converter should have given enough 12v power to run the slides if the discount is on.
  • Will charge battery......thanks.....was told that 12.2 v was ideal for the RV....
  • 12.6 to 12.8 would indicate full charge
    You need a strong battery to run the slides.
    Jerry
  • Got news for ya.... 12.2 volts is only about 50% charged.....
    Charge the batteries and see if that makes a difference.
    good luck
    Ron
  • Get out your volt meter and confirm voltage where necessary
