jsikora
Dec 12, 2014Explorer
I had the same issue on our wilderness by fleetwood. There is no module. The switch is a direct run to the motor. We replaced the switch 2 times. After the second time I did some more checking and found they were running the full current thru the switch (hence melting the switch). I added relays in line, with the battery line feeding the relays. This way the switch only is to turn the relay on. Since adding the relays we have had no issues. I suspect all fleetwoods are the same as I know a friend who had a 2004 with the same issue.
About Fifth Wheel Group
