Lineman2's avatar
Lineman2
Remote control module
I have a 2009 Montana 5th wheel model MO3665RE09, my problem is that the remote control module brain that controls leveling, slideouts, ect.from the outside has failed have to replace it twice in the last 6 yrs. I can still operate everything with the fob.
So I guess I am asking if anyone else is having the same problem?
And the only place I can find the replacement part is from Lippert
part # 165257 for $356.00 plus shiping & tax.
NEED HELP
  • You really need to join the Montana owners Club forum (www.montanaowners.com), a free to join, privately owned place for over 15,000 Monatana owners to discuss everything that can and will go wrong.
    Your problem is a common one and is easily circumvented. Here is the content from one post which describes the problem and provide the solution. You can read it all (and much more) at Link
    The Landing Gear and Stabilizers only working with the remote control and not with the outside manual switches has been a topic of discussion here lately. When ours stopped working "zman08" directed me to a post that solved our problem. It involved removing the ground for the manual switches from the remote receiver and grounding it to the chassis. Apparently there is a "failsafe" circuit to keep the user from using the remote switches and the manual switches at the same time. The connections on the receiver in the front compartment only effect the landing gear and stabilizer switches. The failsafe will not provide a ground to the manual switches when the remote system is energized and will sometimes get "locked" in that position. That is what happened to ours. Like I said, I just moved the ground from the receiver to the chassis and everything works again. You can replace the receiver module, but I think Lippert wants around $150-$200 for it and it will probably just fail again. Our rig is out of warranty so this was the best economical fix for us. I have included a couple of photos of where the wires are for the manual switches and where I moved the ground to.
    Jack
    Manual switch wires "To Manual Switches"
    Where the ground was relocated to
    Moderator edit to re-size pictures to forum limit of 640px maximum width.
  • You have a fob, and a remote? We have the remote, but I think I've used it twice. Seems more like a gimmick than anything really useful. Consequently I've never had any issues with the controls. It's a 2010 Fuzion, and the remote works the slides, awning, security light, and rear stabilizers. Maybe the front ones too, but I can't really remember.
