- remdog_1ExplorerBoeshield t-9
- I use a spray can of graphite that goes on like paint.
I use Slip-Plate brand and there are others. - George_HExplorerI carry a block of canning wax, rub it on the gears when I think of it (3 or 4 times a year depending on use). 12 years with no rust or noise.
- laknoxNomad
ScottG wrote:
I've used dry lube for years but I recently noticed that after I run the slide in and out a couple of times, the lube is gone and the teeth start rusting.
I'm going to try something a little more clingy, like chain lube. I don't care if it attracts dust - it's still better than metal on metal gear gnash.
If your getting a lot of squeal when the slides are moving, you might look and see if your system has some rubber rollers that the floor runs on. I found that all the horrendous screeching was coming from these wheels.
They're mounted on a simple bolt so I supported the slide with a jack, removed the bolts and greased them.
Slide has never run so quiet!
We used to put a squirt of graphite powder in the seed boxes of our planter with each refill and the seed plates would still rust when it was humid. Just because there's rust, doesn't mean that there's no lube. Just sayin'...
Lyle - BobKrogstieExplorerI use this one: 3-in-1
- ScottGNomadI've used dry lube for years but I recently noticed that after I run the slide in and out a couple of times, the lube is gone and the teeth start rusting.
Slide has never run so quiet! - BB_TXNomad
- laknoxNomad
copper canyon 252 wrote:
Going to clean the slideout rails so it want be so loud . What type lube do yall use
My old Komfort said "clean, no lube". Can't remember what the manual for my new KZ says (need to re-read). Use a "dry" lube, if anything. Keeps dirt and other cr@p from sticking.
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
