- billmacExplorerIs your slide out electric or hydraulic. My rv has hydraulic slide outs and there is no manual slide out crank.
If pump motor fails, a 5/16 nut on the end of the motor will let a drill spin the pump. The nut is hidden under a rubber grommet. - MFLNomad IICan't say on your Cougar, but on many, the access hole to insert the crank handle is on the opposite side of trailer from slide. If you mean you can't find the crank handle, it could be anywhere, but likely in a pass through storage.
Jerry
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
