DRM796's avatar
DRM796
Explorer II
May 30, 2015
Slideout seal caulk
What do you use to caulk the slideout seals that are on the exterior wall. I have used Proflex around the front cap and other seams. However the caulk currently around the seals does not look the same as the other caulk. Thanks.
  • It's still hard to tell what's going on in that pic. Did you buy this rig used? (Sorry. "new to you")
    Did a previous owner do that?
  • I have not been able to figure out how to post a pic in th eprly so I added athe pic in my profile hope that shows up.
    click on view profile and you can see the pic.
  • Trying to post a picture. Hope it works. But on the wall fo the camper were the slide seal is mounted mine have all been caulked between the wall and the rubber seal and some areas are starting to pull away from the rubber.
  • That's a new one on me. No caulking there. Slides move.
  • I don't think my slide seals even have, "caulk."..?
    I'll have to go and look.
